"Add Physics" window not showing
Today I created a new Comsol study, beginning with just "laminar flow" as Physics. When I wanted to add a "heat transfer" Physics, I right clicked on "component 1", then selected "Add Physics". The "Add Physics" window did not open. Even after closing and reopening the mph-file, I could not get the "Add Physics" window to open. The Comsol version is 5.3. Does anyone know the probable cause or a solution?
2 Replies Last Post 16 avr. 2018, 05:38 UTC−4
Thure Ralfs COMSOL Employee
Posted: 6 years ago 16 avr. 2018, 05:16 UTC−4
Maybe the frames have been relocated and thus not visible. From the Home tab/ribbon you can select "Reset Desktop" and then try again.
Posted: 6 years ago 16 avr. 2018, 05:38 UTC−4
I have tried that; the "Add Physics" window does not show up. I have also tried to make all the windows floating, and I have moved them around to see if the "Add Physics" window was hidden behind one of the docked window. It was not; there simply was no visible "Add Physics" window.
