FSI
i am doing the fluid structure interaction using the Comsol modal library named vibrating beam in the fluid flow. and I want to scale down the model. the default beam dimensions are in meters. If I am changing the dimension to cm. the solution does n
I want to scale down the model such that the thickness is aroung 1/2 mm. . . I have tried changing the dimentions manually in meter scale too but that is also not working. . .
0 Replies Last Post 20 avr. 2018, 12:01 UTC−4
Hello P. C. Rajgopalan
