how to define and assemble several parts using Comsol ONLY
Hey guys,
I have moved from ANSYS classic to Comsol 4.1 so im a rookie working with comsol. Now, I have to study
a free flex pivot and I kindda need to do everything in Comsol (that means NO CAD software, NO import, nothing)
basically cause I wanna know if comsol can do the task alone.
another reason why I do NOT use a CAD import is cause of previous issues during the import process.
I have lets say two models defined and i can toggle between them in tree navigation bar on the left, but i can not dragg one into another or have both models in one working space at the same time to assemble (a typical procedure in inventor or solidworks).
What am i missing here? could some one give me a tutorial on assembly please?
thank for your help in advance.
Ali
4 Replies Last Post 5 mai 2011, 08:59 UTC−4
Posted: 1 decade ago 4 mai 2011, 02:13 UTC−4
Update:
I got to export the parts one by one, opened a new model and imported the geomtries ,again, one by one and Comsol put them on each other with respect to the coordinates, So that means you have to design every single part with respect to one origin.
FYI im posting my progress cause some other rookie might find it useful :)
Update: I got to export the parts one by one, opened a new model and imported the geomtries ,again, one by one and Comsol put them on each other with respect to the coordinates, So that means you have to design every single part with respect to one origin. FYI im posting my progress cause some other rookie might find it useful :)
Posted: 1 decade ago 4 mai 2011, 03:09 UTC−4
why not import from a cad in parasolid format ? or use one of the Livelink, much easier. And even if the COMSOl CAD is somewhat primitive, compared to a true CAD tool today, its already quite powerful
Hi why not import from a cad in parasolid format ? or use one of the Livelink, much easier. And even if the COMSOl CAD is somewhat primitive, compared to a true CAD tool today, its already quite powerful -- Good luck Ivar
Posted: 1 decade ago 4 mai 2011, 03:17 UTC−4
Hi Ivar,
Like I said, the point of my task is to see if Comsol can do it alone.I have to wait three weeks before i get my hands on a CAD program and I want to see if Comsol can do the job, AND I am guessing that would make meshing easier, based on my ANSYS experience at least.
Comsol really need to up their game in design section.
Hi Ivar, Like I said, the point of my task is to see if Comsol can do it alone.I have to wait three weeks before i get my hands on a CAD program and I want to see if Comsol can do the job, AND I am guessing that would make meshing easier, based on my ANSYS experience at least. Comsol really need to up their game in design section.
Posted: 1 decade ago 5 mai 2011, 08:59 UTC−4
well my experience is that meshing from a CAD model or from a COMSOl model is 100% the same, but IFF you apply the same rules: cut up your volumes such that you can easier select subsections for the manual meshing process, open up loops etc. This can be done as easily in Solidworks (or other I suppose) than in COMSOL. ANyhow construct your CAD model with meshing in mind, particularly if you have complex geoemetries
Hi well my experience is that meshing from a CAD model or from a COMSOl model is 100% the same, but IFF you apply the same rules: cut up your volumes such that you can easier select subsections for the manual meshing process, open up loops etc. This can be done as easily in Solidworks (or other I suppose) than in COMSOL. ANyhow construct your CAD model with meshing in mind, particularly if you have complex geoemetries -- Good luck Ivar
