Question On variable dependent on solution.
I have a question.
I want to know how the current divides in the superconducting wire. In order to solve this problem, i must know about the material property of superconducting wire. finally I found almost of them.
But it's important that the resistivity is dependent on temperature and "current density" both.
i know how i can handle the variable dependent on temperature in transient mode(I used a electro-thermal interaction mode) but i can't find any method in variables depend on solution in manual. I read the "analytic variables" part in the variable section. but There isn't any example so I can't understand and can't convince that it it what i want.
so I want to know how i can handle problem
please give me some tips
Thank you
0 Replies Last Post 23 nov. 2009, 08:26 UTC−5
Hello Won Hee Sung
