How to get Complex geometry from import mesh
Hi, all!
Recently, I have generate Comsol mesh from other software, but I found it is hard to define boundary condition, so I want to convert import mesh to Geometry. Is there any convenient way of doing this? Thanks in advance
4 Replies Last Post 8 juin 2011, 07:03 UTC−4
Posted: 1 decade ago 7 juin 2011, 08:57 UTC−4
Hi, all!
Hi, did you try (in Comsol 3.5a):
Mesh > Create Geometry From Mesh?
PM
[QUOTE] Hi, all! Recently, I have generate Comsol mesh from other software, but I found it is hard to define boundary condition, so I want to convert import mesh to Geometry. Is there any convenient way of doing this? Thanks in advance [/QUOTE] Hi, did you try (in Comsol 3.5a): Mesh > Create Geometry From Mesh? Regards, PM
Posted: 1 decade ago 7 juin 2011, 17:28 UTC−4
Yeah, I took a try to generate 3D geometry, but it showed
Error: 2211
Face cannot be parameterized.
- Face: 1
I really have no idea about this error, could you do me a favor to let me know? Or are there any other ways? Thanks for your help
Lichu
Yeah, I took a try to generate 3D geometry, but it showed Error: 2211 Face cannot be parameterized. - Face: 1 I really have no idea about this error, could you do me a favor to let me know? Or are there any other ways? Thanks for your help Best, Lichu
Posted: 1 decade ago 8 juin 2011, 04:23 UTC−4
I'm struggling with imported mesh too. When I get this error, I usually try to simplify the surface - and therefore the mesh within - with the original software you're using to create it. By the way, what program is it?
It's a sort of trial-and-error process.
Prisca M
Hi, I'm struggling with imported mesh too. When I get this error, I usually try to simplify the surface - and therefore the mesh within - with the original software you're using to create it. By the way, what program is it? It's a sort of trial-and-error process. Regards, Prisca M
Posted: 1 decade ago 8 juin 2011, 07:03 UTC−4
the main issue you are fighting with (for me too when I receive a meshed model from a client to reuse) is that the mesh is not the "Geometreical Entities" onto which you apply the physics in COMSOL.
If so, it yould mean you have thousands of internal continuity boundaries to handle etc. A headache to geep track on
The real issue is how to transform a meshed geometry, composed of small "mesh elements" into a macroscopic geometrical object (via some external software), then to import this "higher level geometry" into COMSOL to apply the physics directly to this macroscopic geometry, AND NOT on the individual mesh elements
This is a quite different methodology between COMSOL and other more tradiational FEM tools, and it's the key for the efficiency of COMSOL w.r.t. the others, apart for such cases , when the geometry comes already "fine meshed"
v3.5a was quite good to recombine a mesh into higher level geometry, when the shapes where simple (cubes, prisms ..., not fully for spheres, circles ... and not really at all for fully free meshed surfaces
Hi the main issue you are fighting with (for me too when I receive a meshed model from a client to reuse) is that the mesh is not the "Geometreical Entities" onto which you apply the physics in COMSOL. If so, it yould mean you have thousands of internal continuity boundaries to handle etc. A headache to geep track on The real issue is how to transform a meshed geometry, composed of small "mesh elements" into a macroscopic geometrical object (via some external software), then to import this "higher level geometry" into COMSOL to apply the physics directly to this macroscopic geometry, AND NOT on the individual mesh elements This is a quite different methodology between COMSOL and other more tradiational FEM tools, and it's the key for the efficiency of COMSOL w.r.t. the others, apart for such cases , when the geometry comes already "fine meshed" v3.5a was quite good to recombine a mesh into higher level geometry, when the shapes where simple (cubes, prisms ..., not fully for spheres, circles ... and not really at all for fully free meshed surfaces -- Good luck Ivar
