ODE Loops - Are there any possibility to enforce the ODE dependent variable back to initial value?
Hi all
ODE. Basically, I need to calculate ODE integration of alpha(t,T) for 4 loops. My equation is
d(alpha)/dt = A*exp (-E/RT)*(1-alpha)^n
with I.C. alpha(0,T_1) = 0
First, I use the integration on globe eq as following
alphat-intop1(A*exp (-E/RT)*(1-alpha)^n) : alpha_0 = 0, alphat_0 = 0
no problem for the first loop, my alpha is well behave between 0-1 as I expected.
when I tried to solve for the second loop, I have the problems. As I can't set the alpha back to the original value, the calculation is not correct... :_(
Are there any possibility to enforce alpha = 0 again when (alpha >= 1) ?
many thanks
Krit
0 Replies Last Post 18 juin 2011, 17:09 UTC−4
Hello Krit Jiamjiroch
