error in automatic sequence generation Syntax error in expression
I am making a electromagnetic model about eddy current testing.
The model consists of several domains(air, plate, shield, coils, flaw).
When I try to solve it, I got the message as this
-Expression:(0)+()
-Subexpression:()
-Position:5
Could anyone help me? Thanks advance.
Best regards
2 Replies Last Post 17 oct. 2011, 02:44 UTC−4
Hello Noritaka Yusa
Posted: 1 decade ago 15 oct. 2011, 13:05 UTC−4
I have the same error in same kind of model.
Anybody Please help.
Mr.Ivar..??
I have the same error in same kind of model. Anybody Please help. Mr.Ivar..??
Posted: 1 decade ago 17 oct. 2011, 02:44 UTC−4
not clear what it means, but it could be that you have an "empty" field, check if yll your BCs are filled in. Or rebuild your model.
Note: always use the latest version, or at least forget 4.0 to 4.1, these vere early version after the v4 (r)evolution and not fully ironed out ;)
Hi not clear what it means, but it could be that you have an "empty" field, check if yll your BCs are filled in. Or rebuild your model. Note: always use the latest version, or at least forget 4.0 to 4.1, these vere early version after the v4 (r)evolution and not fully ironed out ;) -- Good luck Ivar
