Gunnar Andersson
COMSOL Employee
5 years ago
22 févr. 2019, 02:09 UTC−5
You can use a plot selection subnode to achieve the effect that you want: Create e.g. a contour plot, add a selection subnode to the plot, choose the explicit selection in the selection subnode, plot. The selection attribute wasn't available when the original question was asked, so at that time the best solution would be to add a selection subnode to the solution data set that the plot refers to.
5 years ago
22 févr. 2019, 16:05 UTC−5
Updated:
5 years ago
22 févr. 2019, 16:06 UTC−5
Hmm perhaps this is only on Windows? I usually use Linux, and if I remember correctly I definitely checked the context menu for subnodes on the plot and it offered filter subnodes but not selection. If it is available for Linux and I have missed it I would be interested to know.
In any case, I really need a programmatic selection technique and not just a plot subnode so that I can selectively manipulate data outside certain regions of interest when exporting data on a grid. So for example it would be nice to export es.normE * (selec==3) instead of es.normE * (dom==1 && dom==3 ...) For the time being I have successfully implemented a workaround of defining different materials to represent the selection, so that i can export es.normE * (material.domain==1) for example.
Gunnar Andersson
COMSOL Employee
5 years ago
25 févr. 2019, 02:07 UTC−5
The plot selection subnode is available also on Linux. It was introduced in 5.3.
There isn't any corresponding subnode for data export nodes, but I think that you should consider using data set selections instead of the expression manipulation that you are using now. E.g., create a solution data set, add a selection to the data set, create a data export node, point it to the data set with the selection.
