Particle tracing in fluid flow
Posted 13 mars 2012, 10:23 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Studies & Solvers Version 4.2a 0 Replies
I have a problem with the particle tracing module, likely a newbie one.
I started from the "Flow Past a Cylinder" tutorial and added a Particle Tracing for Fluid Flow (fpt) physics node to perform a simple massless particle tracing computation. The issue is that I cannot get any particle solution or access that. As far as I understood once the solver is running a Particle data set should be added, but in my case this does not happen.
I attach the model to this post, it is a simple model fortunately... probably the solution is just out there and I cannot see it.
Any hints is greatly appreciated.
J
Hello J
