Time dependent study of multiturn coil
Hi, I am a new user of Comsol Multiphysics. I want to study the time dependent response of two multiturn coils of finite dimension and In each coil the mangnitude of current is same but has a phase difference of 90 degree. I want to visualize the rotating field. I am not being able to perform the simulation.Can anyone help me?
1 Reply Last Post 27 sept. 2020, 14:55 UTC−4
Dave Greve Certified Consultant
Posted: 4 years ago 27 sept. 2020, 14:55 UTC−4
  1. There are examples that are helpful. Start with the built-in examples, then do a search on this website.
  2. Unless there is more to the problem, you are describing something best solved as frequency dependent not time dependent.
1. There are examples that are helpful. Start with the built-in examples, then do a search on this website. 2. Unless there is more to the problem, you are describing something best solved as frequency dependent not time dependent.
