Dirichlet Boundry layer
I am trying to build a 2D model that simulate the distribution of electric field.So i am solving the LaplaceEquation with Dirichlet Boundary conditions.My problem that whenever i am trying to select the boundaries of my geometrical shape , it indicates that the boundaries are not applicable. So i would really appreciate if you can help me
Thanks in advance
3 Replies Last Post 6 juin 2012, 00:56 UTC−4
Posted: 1 decade ago 5 juin 2012, 15:23 UTC−4
your geoemtry is a set of lines butare not closed to form a "solid geometric object", try a Convert to solid and select all and you will get a surface, this defines your 2D "domain" with corresponding "boundaries"
Hi your geoemtry is a set of lines butare not closed to form a "solid geometric object", try a Convert to solid and select all and you will get a surface, this defines your 2D "domain" with corresponding "boundaries" -- Good luck Ivar
Posted: 1 decade ago 5 juin 2012, 16:14 UTC−4
Thanks for your Reply
what i am trying to do exactly is to represent a symmetry of sphere for my domain.So my domain is air surrounded by boundary conditions which is steal in my case .So i do not understand you saying that i need to convert my geometry to solid object.So my voltage values across the boundary is zero except at point which represent a small semic-circle within my domain where my voltage value is 9000 Voltage.
Thanks for your Reply what i am trying to do exactly is to represent a symmetry of sphere for my domain.So my domain is air surrounded by boundary conditions which is steal in my case .So i do not understand you saying that i need to convert my geometry to solid object.So my voltage values across the boundary is zero except at point which represent a small semic-circle within my domain where my voltage value is 9000 Voltage. Thanks
Posted: 1 decade ago 6 juin 2012, 00:56 UTC−4
its part of the Geometry principles of COMSOL. for a 2D problem you need a closed defined 2D surface, you have only the lines around, so you need to groupe these into a surface, this is called "CONVERT TO SOLID" even if you are in 2D.
The naming convention is that in 3D a domain is a volume and a boundary is a surface, while in 2D a domain is a surface and a boundary is a line (check your doc, it's essential that you master well these conventions, it will save you days of misunderstanding and frustrating work
Hi its part of the Geometry principles of COMSOL. for a 2D problem you need a closed defined 2D surface, you have only the lines around, so you need to groupe these into a surface, this is called "CONVERT TO SOLID" even if you are in 2D. The naming convention is that in 3D a domain is a volume and a boundary is a surface, while in 2D a domain is a surface and a boundary is a line (check your doc, it's essential that you master well these conventions, it will save you days of misunderstanding and frustrating work -- Good luck Ivar
