mems
I'm doing thickness otimization using moving mesh.i'm able to change the length but i get same displacement for every thicknesss.did i need to do remeshing to mesh the new one if so how can i do remeshing
1 Reply Last Post 3 juil. 2012, 08:57 UTC−4
Posted: 1 decade ago 3 juil. 2012, 08:57 UTC−4
that depends how you set up your model, but are you sure you need ALE ?
If your geometry is simple use a Parameter for the critical thickness, and ADD a parametric sweep node above your first solver step and adjust the parameter there then solve.
Do not use a continuation sweep as that will not perfrom any "remesh" nor Geometry update
Hi that depends how you set up your model, but are you sure you need ALE ? If your geometry is simple use a Parameter for the critical thickness, and ADD a parametric sweep node above your first solver step and adjust the parameter there then solve. Do not use a continuation sweep as that will not perfrom any "remesh" nor Geometry update -- Good luck Ivar
