1 year ago
6 déc. 2022, 12:13 UTC−5
The BH curve checker solved my problem
1 year ago
7 déc. 2022, 09:06 UTC−5
Good news!
1 year ago
8 déc. 2022, 16:57 UTC−5
Good news!
Hi Mark!
I had one more question. So the bh curve solver did solve my problem for the inner shield; however, I now added the second larger shield, and the simulation fails to compute again. This shield is made out of mu metal, and I put the mu metal bh curve into the bh curve checker, and it said that no optimization is needed for this material. The material already has enough data points. However, the bh magnetization model is what is causing the problem because when I use the relative permability rather than the bh curve for the mu metal larger shield, the simulation computes. But, when I put it back to the bh curve model, it does not compute. I doubled checked everything and do not see any differences between the inner shield and the outer shield, so I am not sure what the problem is. It is the same error that I saw before about reaching the max number of iterations. I tried computing with different meshes to see if either increasing or decreaing the degrees of freedom helped; but it still does not work. If you or anyone has any other suggestions please let me know!
>Good news!
Hi Mark!
1 year ago
12 déc. 2022, 03:35 UTC−5
Updated:
1 year ago
12 déc. 2022, 06:25 UTC−5
I will take a look when I can... what is the reason for the "ignore edges" virtual operation?
Edit: some further troubleshooting steps: You say the solution fails when the outer shield is used with the BH curve definition...
a) if you remove the inner shield completely, does it solve then?
b) If not, does it solve if you make the outer shield with the Silicon Steel material?
If "a)" solves, then it might indicate that the inner shield is reducing the field seen by the outer shield and shifting the operating point of the outer shield to a portion of the mu-metal curve that is still poorly defined (even if it does pass the "BH checker" test).
If "a)" fails to solve, then it would indicate that the BH curve of the mu-metal is still problematic (or the mesh needs some attention)
If "b)" solves, then again it would indicate something wrong with the mu-metal BH curve
If "b)" fails to solve, then it might indicate a geometry or meshing issue.
A process of elimination should help pinpoint the issue...
1 year ago
12 déc. 2022, 17:18 UTC−5
Hi Mark,
The mesh just seems to be more uniform when I ignore the edges. I do not think that it would make much of a difference if I disabled the ignore edges. However, I took the inner shield away, and then the mu-metal outer shield did compute. I am not sure how to fix this because the bh curve checker says that no optimization is needed for the mu-metal.
Hi Mark,
1 year ago
14 déc. 2022, 08:00 UTC−5
Updated:
1 year ago
14 déc. 2022, 08:03 UTC−5
It may be running out of memory on your machine possibly (your problem is much more non-linear using the BH representations, and hence more memory intensive)... what memory use is being report during the solve process?
To summarise, it seems both shields solve in isolation, but combining both shields into the same model causes issues... is this the case?
Are you investigating different coil drive voltage/currents? I will try to explain why I ask this...
What is the end result you are looking for... are you looking to reduce the field at a certain location outside the shields to a certain value? If this is the case, I am wondering if you can represent the inner shield by a relative permeability (mu_r) representation, (you will need to determine what value of mu_r gives you the same field result at your point of interest, as the inner shield alone gives when represented by the BH curve). Once you have determined this "equivilent mu_r", you can add in the outer shield and represent it with the BH curve.
Of course, if you coil current is varying, then the mu_r figures will also vary, as you will be operating at different points on the BH magnetisation curve depending on the magnetising field from the coils...
I don't think I can suggest anything else, but Comsol support may be able to identify some more efficient solver setup for the BH curve models...
Footnote:
With care, you may be able to extend this approach, by also determining an equivilent mu_r for the outer shield, the final model would then be mathematically simpler to solve (using two "mu_r" representations, rather than two non-linear BH representations), and should further reduce memory requirements.
Edit: Have you tried using linear discretisation (set in the mf node Settings pane)?
Footnote:
