Joule heating
I am trying to study the joule heating by applying a current density to a material (simple block). I know how to do this by applying a ground and potential boundaries to the block (making a current pass through it) and it heats. What I want to do is, instead of applying a potential difference, I want to define the current that passes along the material. Is it possible? Thank you.
3 Replies Last Post 14 nov. 2012, 01:44 UTC−5
Posted: 1 decade ago 12 nov. 2012, 10:06 UTC−5
Apply a Boundary Current Source node at the boundary that has Electric Potential node in your model.
Posted: 1 decade ago 12 nov. 2012, 14:25 UTC−5
I would add: and disable the "electric potential" or "terminal" node, as you should only keep one of these three active at the sime time on the same boundary
Hi I would add: and disable the "electric potential" or "terminal" node, as you should only keep one of these three active at the sime time on the same boundary -- Good luck Ivar
Posted: 1 decade ago 14 nov. 2012, 01:44 UTC−5
Of course :)
But I think COMSOL overwrites the former with the latter BC by default, so it should work anyway...
Of course :) But I think COMSOL overwrites the former with the latter BC by default, so it should work anyway...
