How to model residual thin film stresses as a boundary condition
Christian Dahl-Petersen
Hi Forum,
I'm trying to model a thin Nitride film on top of a "thicker" silicon membrane, however, I cannot seem to find the right way of modelling the initial (tensile in-plane) stress in the thin film. Tried the Boundary load boundary conditions but it does not seem to produce the right results.
Best Regards
Christain
3 Replies Last Post 26 nov. 2012, 00:52 UTC−5
Posted: 1 decade ago 23 nov. 2012, 07:45 UTC−5
My way is to use temperature induced stress (as othen the stress is build up like that), see the model library example
Hi My way is to use temperature induced stress (as othen the stress is build up like that), see the model library example -- Good luck Ivar
Posted: 1 decade ago 24 nov. 2012, 14:24 UTC−5
Hmm, my problem is that its not thermally build stress (well to be true it is thermally build, however, that is before the modelled device is made). So i need to apply it somehow as a boundary in order not to mesh the verythin film. Isnt that possible in COMSOL...?
Posted: 1 decade ago 26 nov. 2012, 00:52 UTC−5
have you checked the model library layered_plate ? For me this is the cleanest way to get a full stress tensor correctly aligned
Hi have you checked the model library layered_plate ? For me this is the cleanest way to get a full stress tensor correctly aligned -- Good luck Ivar
