Connecting materials
I am trying to connect two separate domains, composed of different materials.
What kind of boundary conditions should I impose to achieve it?
Thank you.
1 Reply Last Post 8 avr. 2013, 00:52 UTC−4
Posted: 1 decade ago 8 avr. 2013, 00:52 UTC−4
it depends what you want to do, but in 90% of the cases the standard default "continuity" that you get from a standard geometry "union" Finish mode is what is required
Hi it depends what you want to do, but in 90% of the cases the standard default "continuity" that you get from a standard geometry "union" Finish mode is what is required -- Good luck Ivar
