Change the directory for "store solution on file" option.
Hi all,
I have a quick question about COMSOL. I am trying to change the directory to save temporary files from C drive to D drive because C drive does not have enough free space.
And I tried the following command from the manual:
For the -tmpdir option, COMSOL software uses the specified directory to store temporary files.
However, it did not work.
If you know how to solve this problem, please let me know.
Sang Jun
1 Reply Last Post 28 août 2009, 01:30 UTC−4
Posted: 1 decade ago 28 août 2009, 01:30 UTC−4
I can just state for us, the redirection has always worked, lateston V3.5 on PC Vista and since 3.5a on unix, so I can only suggest that you recheck your shortcuts or launch ccomands carefully and try again,
Hi I can just state for us, the redirection has always worked, lateston V3.5 on PC Vista and since 3.5a on unix, so I can only suggest that you recheck your shortcuts or launch ccomands carefully and try again, Good luck Ivar
