coupling variables
When I define coupling variables, I must define source and destination vertices, but I don't understand their meanings. If I change the number or the order of source vertices (on the same boundary), solution changes. The sane happens for destination vertices. Why?
Thank you!
Ramona
1 Reply Last Post 3 oct. 2009, 21:12 UTC+2
Posted: 2 decades ago 3 oct. 2009, 21:12 UTC+2
there are relly many cases to consider, I would propose that you start by running a indexed search on the help files, or directly on the PDF documentatin, us the keywords "Coupling Variables" there are many examples described, then try out a few.
And do not hesitate to come back if you have more questions
Hi there are relly many cases to consider, I would propose that you start by running a indexed search on the help files, or directly on the PDF documentatin, us the keywords "Coupling Variables" there are many examples described, then try out a few. And do not hesitate to come back if you have more questions Good luck Ivar
