inquiry on how to get the numerical solution
Hello fellow readers and Dear Moderators,
Greetings.
I just would like to ask on how i could obtain the numerical values from the multiphysics that i had run.
so far i was able to run correctly the simulation on the thermal diffusion but only the 3D graph is only available.
I already tried running the graph on 1D but to no avail.
Any idea on how i could the get values so that i could compare the simulated values with the experimental results.
I appreciate much of your suggestions.
Thank you and God bless.
Jonathan
2 Replies Last Post 10 oct. 2010, 20:19 UTC−4
Posted: 2 decades ago 10 oct. 2010, 05:59 UTC−4
if you are in V4, plot out a cut line data andcut&paste it into Excel, or an simple txt file.
In 3.5 I usually used matlab with a postinterp onto a self defined grid
Hi if you are in V4, plot out a cut line data andcut&paste it into Excel, or an simple txt file. In 3.5 I usually used matlab with a postinterp onto a self defined grid -- Good luck Ivar
Posted: 1 decade ago 10 oct. 2010, 20:19 UTC−4
Dear Mr. Ivar,
Thanks for the help.
I will try what you have said.
Thanks again and May God bless you.
Jonathan
Dear Mr. Ivar, Thanks for the help. I will try what you have said. Thanks again and May God bless you. Jonathan
