Data Set: Array 3D on triangular lattice?
Hi all,
I have question regarding the Array 3D datasets (under the Data Sets section in the Results node). It natively creates an array of the input dataset with a periodicity in x/y/z, so that the initial dataset appears on a kind of rectangular lattice.
Does anyone know, whether this is possible to change to other arrays for example on a triangular lattice?
I currently try to simulate some fields on a triangular lattice using Floquet boundaries. At the moment I just plot the simplest unit cell (which is kind of a parallelogram), but I would like to extend that to a few unit cells to make the mode shape better visible.
Thanks already in advance!
Hannes
1 Reply Last Post 25 janv. 2016, 02:10 UTC−5
Posted: 10 years ago 25 janv. 2016, 02:10 UTC−5
Only rectangular lattices are supported.
[QUOTE]Does anyone know, whether this is possible to change to other arrays for example on a triangular lattice?[/QUOTE] Only rectangular lattices are supported.
