Heat Flow in Urban Building - Modeling Cooling Process
Posted 1 mars 2016, 03:39 UTC−5 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.1 0 Replies
What I want to do here exactly is to calculate the cooling load of the building by quantifying the heat flux going inside, through the building walls, while fixing the temperature inside the building to a reference value (24 degrees). I'm planning to calculate the cooling load as a function, but I will be needing different variables; namely; the temperature of the inner and outer walls of the building, the temperature and humidity (moisture concentration) just outside the building walls (for the calculation of infiltration), what would be the way to get these values? I know that for the temperature of the walls I need to define an integration operator on the building wall boundary, but I'm not sure how to do it just outside those boundaries.
Hello Dina Masri
