Simulating antenna scattering parameter S11
Posted 1 mars 2016, 18:05 UTC+1 Mesh Version 5.0 0 Replies
I am trying to get the scattering parameter S11 of a patch antenna. In order to avoid reflections, I use PML which is thickness of 1 wavelength.
However, I have marked that S11 results change accordingly to mesh size. I am using physics-defined mesh from normal to extremely fine, and the results are always different, which is confusing.
My question is - how is it possible to tell whether mesh is accurate enough to give trustworthy results?
please find the model attached.
Thanks and regards,
Arturs
Hello Arturs Ivanovs
