Hello Qiulin Ma
15 nov. 2012, 16:50 UTC+1
you are correct, I think the stress distribution is not totally correct, but i can not find a way..........
Aswani Kumar Mogalicherla
9 years ago
12 févr. 2017, 10:51 UTC+1
I am also having same problem
Is there any solution found for it?
9 years ago
12 févr. 2017, 16:54 UTC+1
This is "normal" as a fixed constraint means u=v=w=0 that is NO displacements, but this is not really "physical", your part is fixed to something with a non-infinite Young modulus, and a given Poisson coefficient (the latter links perpendicular swell or contraction to the normal compression/traction) so in reality it will allow some minor displacements at the "fixed" boundary, if not you will get "numerical" stress hotspots for sure.
if you want to study "true stress" when applying theoretical loads toa cube of material (in compression, or in shear etc) then you need to use symmetry conditions, or cut your cube by mid-planes and apply *roller" conditions on these middle surfaces (in 3D you need 3 roller conditions for tensile-compression but only 2 roller conditions for shear forces).
You might also apply more sophisticated weak conditions to your "fixed boundary" to keep it "flat" etc
Two more caveats:
if you solve for non-linear geometrical displacement, then you should NOT use symmetric BC as this will give you further artificial numerical stress values, since the non-linear theory adds an anti-symmetric factor to your displacement calculations, hence in collision with a symmetric BC.
If you solve for thermal expansion, be aware that many of the "fixed, or Rigid Connector" BC have now an optional thermal expansion sub-node, that allows to compensate for the local thermal expansion effect on these "fixed" boundaries
Two more caveats:
Henrik Sönnerlind
COMSOL Employee
9 years ago
13 févr. 2017, 16:56 UTC+1
This is also discussed in
https://www.comsol.com/blogs/singularities-in-finite-element-models-dealing-with-red-spots/
Henrik
