Comsol Paralel Computing Problem !
I want to use Comsol Paralel computing with Windows HPC 2008 R2. There are five Nodes one of which is Head-Node (Windows SERVER HPC). Among the workstations one Head-Node + quantity of four Workstation Node(Windows 7 ) only A workstation Node works actively with Parallel computing and when I try to make the others WORK, it says " Scheduling" and it freezes like that gives no other error.
All the settings in A workstations exist also in B-C-D Workstation Nodes. What might be the reason for Comsol being not able to make parallel computing between Head-Node and A Node while it makes it with the others? If that was a license problem, should not it suppose to give an error between A and Head-Node? Which parts I should check on Windows HPC and Comsol?
Thankyou.
0 Replies Last Post 17 mars 2016, 20:39 UTC+1
Hello Alper Aykut
