Hello Mohammad Amin Kazemi
9 years ago
2 juin 2016, 04:55 UTC−4
Hi Amin
I have the same issues with the “laminar two-phase flow, moving mesh” physic in dependence on the contact angle.
Im modelling evaporation of a sessile drop. With “transport of diluted species“ physic the evaporation flux is calculated. The deformation of the drop im modelling with the „laminar two flow, moving mesh“ where the mass flux on the fluid-fluid-interface is coupled with the evaporation flux. With a contact angle of 90° the deformation seems okay, but when the contact angle is set bigger the resulsts get physically meaningless like in your simulation.
Did u solve the issue and could give me some advice? Im using COMSOL 5.0 and I wasnt able to open the attached file because it was saved with a later version of COMSOL.
Thanks in advance.
Lars
Hi Amin
Thanks in advance.
Lars
9 years ago
2 juin 2016, 14:05 UTC−4
Hi Lars
The solution is that you should exclude the contact points in the expression for evaporation flux.
In my geometry, since the r-position of the contact point was always fixed, I used this expression for flux:
if(r<5mm,flux,0)
This means that the evaporation flux is imposed on the interface except at r=5 (SLV contact point).
I recommend you contact COMSOL support and ask if they have a better solution.
Let me know if I can be of assistance.
Amin,
Hi Lars
if(r
9 years ago
29 mars 2017, 23:23 UTC−4
I have brought about my question once again since I couldn't find any answer yet. I appreciate if one of COMSOL employees answer it.
Question:
In the "laminar two-phase flow moving mesh" physic (tpfmm), when I impose a small amount of flux on the interface, it moves much faster than expected. Is it a bug in COMSOL? This happens for curved interfaces when the contact angle (theta) is not 90. For flat interfaces (theta=90), everything is fine.
I have been struggling with this issue for several months. I appreciate if someone can help.
Amin,
Question:
Amin,
Jeff Hiller
COMSOL Employee
9 years ago
30 mars 2017, 07:57 UTC−4
To address a question to the COMSOL support team, contact support@comsol.com . Please note that this service requires that your license be eligible for that service.
9 years ago
30 mars 2017, 11:44 UTC−4
Unfortunately, my license is not eligible for this service. I wish someone could answer.
Thank you anyway.
Amin,
[QUOTE]
[/QUOTE]
Thank you anyway.
Amin,
