Partition Function Derived Values
Posted 28 mars 2016, 16:42 UTC−4 Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization Version 5.1 0 Replies
I am deriving some values from my model which I use for calculations in a thermodynamical ensemble. For this reason, I have one derived value, the partition function, which several other derived values need to reference for appropriate normalization.
The partition function is a triple integral over a certain volume in my case, while some of the other derived values are fluxes- double integrals over some area with a velocity integral. For this reason, I can't calculate the partition function as part of the flux calculation, as the integrals have different domains.
Is there any way that I can use the scalar result of my triple-integral partition function calculation in my other derived values?
An obvious workaround is to do the partition function integral first and put the number in by hand, but I always strive to use the cleanest technique to solve problems in order to minimize mistakes.
David
Hello David Reens
