In-floor heating system
Hi,I'm interested in using the program in my master thesis. I want to simulate an in-floor heating system in an urban environment.Can this be done?
Thank you.
Christina
1 Reply Last Post 14 avr. 2016, 11:34 UTC−4
Posted: 10 years ago 14 avr. 2016, 11:34 UTC−4
Hello Christina,
Yes, it is possible to model radiant floor heating. You would use the Pipe Flow Module for that type of modeling: www.comsol.com/pipe-flow-module .
See also this example: www.comsol.com/model/heat-recovery-system-for-a-geothermal-heat-pump-18529 .
Hello Christina, Yes, it is possible to model radiant floor heating. You would use the Pipe Flow Module for that type of modeling: https://www.comsol.com/pipe-flow-module . See also this example: https://www.comsol.com/model/heat-recovery-system-for-a-geothermal-heat-pump-18529 . Best regards, Jeff
