Importing a 2D CAD file into COMSOL
I am trying to import a 2D CAD file into COMSOL 3.5 that was generated from a CAD software and I get the error below.
"Error: 3034 - Imported geometry contains no geometry objects."
The 2D file is just a cross-section of a 3D CAD geometry that I have.
I have tried several import options including .igs, .stp, and .sat. All of these options give the same error.
Can anyone suggest a way to import these 2D cross-sections into COMSOL?
2 Replies Last Post 25 oct. 2016, 03:10 UTC+2
Posted: 1 decade ago 8 nov. 2010, 07:16 UTC+1
in 3.5 you can only import "dxf" in 2D mode
Hi in 3.5 you can only import "dxf" in 2D mode -- Good luck Ivar
Posted: 9 years ago 25 oct. 2016, 03:10 UTC+2
what about in version 5.2a?
I have an image from X-ray CT and made a cross-sectional view of it.
Using image j, I exported it to jpg and tried to import it to comsol, but it did not work out.
What else format works for comsol 5.2??
what about in version 5.2a? I have an image from X-ray CT and made a cross-sectional view of it. Using image j, I exported it to jpg and tried to import it to comsol, but it did not work out. What else format works for comsol 5.2??
