Time study simulation
Arezoo Materials Science
In time dependent study simulation in COMSOL, we need to define range in study setting as below:
range(time1, TIME, time2)
This means that the simulation will be study between time1 and time2, the time duration in each time step is adaptive but it can not bigger than TIME and in each TIME the results will be saved.
I need to decrease TIME because I want to put a restriction to max time step in my simulation not bigger than a particular value, but I don't want to save the results in all TIME steps to reduce the memory space.
how can I solve a study in particular time steps but save the results in some of that time steps?
Arezoo
2 Replies Last Post 16 mai 2016, 09:35 UTC−4
Posted: 10 years ago 14 mai 2016, 10:03 UTC−4
Keep TIME as big as you need just for output of results and limit the maximum time step the solver can take from the Time Stepping tab of the Time-Dependent Solver node.
Nagi Elabbasi
Veryst Engineering
Keep TIME as big as you need just for output of results and limit the maximum time step the solver can take from the Time Stepping tab of the Time-Dependent Solver node. Nagi Elabbasi Veryst Engineering
Posted: 10 years ago 16 mai 2016, 09:35 UTC−4
Thanks so much for your help,
Arezoo
Thanks so much for your help, Arezoo
