Comsol with Matlab 2010b on MacOS X freezes
Posted 17 nov. 2010, 10:04 UTC−5 LiveLink for MATLAB, Installation & License Management Version 4.1 13 Replies
I just installed Matlab 2010b and then COMSOL 4.1 on a new MacBook computer and everything works fine except I cant start "COMSOL with Matlab".
The app tries to start but it just freezes.
I have cheked the mlroot in comsol.ini and comsolserver.ini and they are correct.
When I did this, Matlab opened fine with Comsol lurking in the background. Next time the COMSOL with MATLAB application should work normally. I had to do this for version 4.0a as well. You may need to restart to clear the license manager.
BTW, I get a security issue trying to launch the license manager at startup - do you also?
Hope this helps!
~jim~
ERROR: Could not start COMSOL Application. See log file: /Users/micke/Library/Preferences/COMSOL/v41/logs/server5.log
The file says
among other stuff:
00001:293 ERROR Exception:
com.comsol.util.exceptions.FlException: Matlab root directory and Matlab start command are both undefined
[com.comsol.logger]
Wich is weird since I have the right mlroot specified ( -Dcs.mlroot=/Applications/MATLAB_R2010b.app)
start COMSOL Multiphysics Server.app
start Matlab_2010b.app
type "mphstart" in Matlab.
Can it have anything to do with Matlab 2010b not needing X11 in the background? I can see the comsol launcher opens X11.
(Also, no I don't get a license error...)
have you got the latest COMSOL patch of 2010nov26 ?,
it states it has solved a few Matlab issues, I do not have Mac so I cannot tell if linked to your issue. Then Matlab 2010b is alo rather new ... (compatibility issues are a hell, I agee ot where you want to spend your time)
sorry to hear that, best is to get some help from "support" or your local rep
I doubt it makes any difference, but there is a space before this line and not before any others.
And I do not get your error. Peculiar. At least you have found a method that works!
~jim~
Hope this helps,
~jim~
But the good nnews is that it is not really serious becasue you can launch the app through the command line exactely as in linux [ as explained in the doc under linux section] . Some paths might need to be corrected but these are obvious changes...
jf
Try going inside the COMSOL41 folder, right-click on COMSOL with MATLAB to Show Package Contents. Find ComsolLauncher in Contents/MacOS. Open a Terminal window and drag ComsolLauncher to it. Click inside the Terminal window and hit return. You will be prompted for username and password.
Hope this helps!
~jim~
this is really clever. It works.
Suggested Content
- FORUM Comsol 4.0a freezes temporarily
- KNOWLEDGE BASE COMSOL 6.1 macOS Apple Silicon Native Support
- KNOWLEDGE BASE Update for LiveLink™ for MATLAB® on macOS with Apple Silicon Processors Applicable to COMSOL Multiphysics® Version 6.2
- BLOG Why Is Ice Slippery Enough for Skiing and Skating?
- FORUM COMSOL Freezes
