pressure distribution in rotating cylinder
Posted 22 nov. 2010, 09:13 UTC−5 2 Replies
                                                    Hii,
I am a beginner in COMSOL. I want to model a rotating cylinder filled with air. The surroundings of cylinder is air as well. I want to see the pressure distribution inside the cylinder. The solution is converging and displays the results but I have doubt on its accuracy. Can someone check my model
A major doubt I have is about the geometry: I have placed an air cylinder inside the plastic cylinder...is it right way to model the air inside the plastic cylinder. Should I use the contact pair definition to attach both of them.
I am attaching my model here. Can explain it further if someone could help
2 Replies Last Post 23 nov. 2010, 05:16 UTC−5
