geometry import - subdomain conflict
Posted 22 nov. 2010, 19:35 UTC−5 1 Reply
Dear All,
I am trying to do the following: import an assembly drawn in Inventor into Comsol. I exported the file from Inventor as a *.stp file and imported that into Comsol. The file is imported without any obvious problems.
Later, I need to define a point load in a part of the body that I have imported. Unfortunately, there is no point on where I need to define the point load, so I inserted an additional point using draw, in Comsol GUI. Then I got the error message:
"internal error on geometry decomposition".
I tried to import the geometry as surface instead of solid and checked the use assembly, which led to be able to place the point where I want without getting error messages, but now I cannot assign my point load, as the point appears gray (inactive) in the point list in the point settings menu.
To sum up, I am trying to import a 3D model into Comsol and define a specific point in that body to be able to apply a point load. Any ideas how to do it?
1 Reply Last Post 23 nov. 2010, 05:31 UTC−5
