Adding Layers to an Extrusion After Converting to Solid
Posted 9 juin 2016, 09:28 UTC−4 Geometry 0 Replies
Since there are no available primitives to create a hexagonal prism, I created a hexagon in a 2D workplane and then extruded it. I then converted the object to a solid. For 3D primitives, there is a way to add layers of a given thickness to solids/surfaces. Can the same be done with objects that were extruded from the 2D workplane?
Thanks for any help.
Hello Alexis Mulski
