Heat exchanger
If we have a finned or unfinned pipe in which hot fluid is flowing and heat is rejected to a solid contacting the pipe, and if the fluid velocity is const., which module or modules should I use for the simulation of temperature change. I used fluid thermal interaction tool in 3.5, but encountered some problems when I set the solid deactive in incomp. navier stokes mode.
0 Replies Last Post 29 nov. 2010, 14:04 UTC+1
Hello Ahmet Caglar
