Lars Gregersen
COMSOL Employee
9 years ago
12 juil. 2016, 09:02 UTC+2
Use:
comsolmphserver.exe -login force
Command line options for Comsol programs are explained in the Comsol Reference Manual in the chapter on Running Comsol Multiphysics.
Lars Gregersen
Comsol Denmark
Use:
Lars Gregersen
Comsol Denmark
9 years ago
12 juil. 2016, 10:50 UTC+2
Hi Lars,
Thanks for the reply.
In the Reference Manual, it says that the windows syntax for the comsol server command is:
comsolserver [<options>] [<target arguments>]; and the comsol server option to specify the login name is -user<user>. Does that means I can type : "comsolserver [<user>] [<user name>]" on the comsol client server window to change (or add?) a new user name?
I tried this but nothing happen... How can I know whether I succeed in changing the user name or adding a new one?
Thanks and looking forward to your reply.
Shujun
Hi Lars,
comsolserver [] []; and the comsol server option to specify the login name is -user. Does that means I can type : "comsolserver [] []" on the comsol client server window to change (or add?) a new user name?
Shujun
Lars Gregersen
COMSOL Employee
9 years ago
14 juil. 2016, 09:17 UTC+2
comsolserver isn't the same as comsolmphserver.
To add a little history: Comsol Server is described here:
www.comsol.com/comsol-server
It is a new product introduced with Comsol 5.0. When this Comsol Server was released the server which we use for LiveLink for Matlab (and other client-server setups) was renamed to Comsol Multiphysics Server. The application name for this server is comsolmphserver.exe (comsol mphserver on Linux and Mac).
If everything else fails you can reset your password by deleting this file
c:\Users\<username>\.comsol\v52\login.properties
where <username> is your username on the computer.
Lars Gregersen
Comsol Denmark
[QUOTE]
[/QUOTE]
https://www.comsol.com/comsol-server
c:\Users\\.comsol\v52\login.properties
where is your username on the computer.
Lars Gregersen
Comsol Denmark
9 years ago
16 juil. 2016, 16:48 UTC+2
Thanks Lars! I will try your suggestion soon.
