3d Laminar Flow
Posted 27 juil. 2016, 09:49 UTC−4 Fluid & Heat Version 4.4 3 Replies
                                                    Good Afternoon
I´m trying to run a very simple 3d simulation about an air flow that flows through a cylinder (radius=1,75mm) inscribed in a cube(side=4.3mm). Now, when I put between the inlet and outlet a fixed value of pressure (2000Pa) the simulation run without any problem; But if instead of the value of inlet pressure I put value of the mass flow 0.0007 [Kg/s] the solution does not converge. I tryed to change many settings (solver, tolerance and mesh) but it seems to work just for a very small amount of flowing air, like 13e-9[kg/s], that is a very small value.
I run out of ideas, can please someone help me to figure out on what I have to focus my attention.
Thank you in advance.
Renato Baldanzini
Renato Baldanzini
3 Replies Last Post 27 juil. 2016, 13:48 UTC−4
