meshing
hello !
my model is rectangular PV panel(6 mm thickness) with embedded duct of height 30cm .
I used conjugate heat transfer to compute the temperature of PV
how can I mesh this component in right way with PV of small thickness , and can I used to 2d it is time consuming using 3d, or 2d just used with specific case .
best regard ,
hussein
1 Reply Last Post 31 août 2016, 16:23 UTC+2
Posted: 9 years ago 31 août 2016, 16:23 UTC+2
Hello Hussein,
Thin structures lend themselves well to "sweep meshing". This technique is documented and illustrated by a step-by-step example in the COMSOL Multiphysics Reference Manual, version 5.2a, in Chapter 8. All manuals are accessible through the File>Help>Documentation menu.
As to whether you should go with a 2D model instead of 3D, that is of a matter of engineering judgement and will require knowledge of your system and modeling goals.
Hello Hussein, Thin structures lend themselves well to "sweep meshing". This technique is documented and illustrated by a step-by-step example in the COMSOL Multiphysics Reference Manual, version 5.2a, in Chapter 8. All manuals are accessible through the File>Help>Documentation menu. As to whether you should go with a 2D model instead of 3D, that is of a matter of engineering judgement and will require knowledge of your system and modeling goals. Best regards, Jeff
