9 years ago
22 sept. 2016, 01:49 UTC+2
Simple.
Set the potential to Vcell-Vpot and subsequently use a parameter sweep on the Vpol from 0.01 up to the value you want (0.5 for example, because at lower value of voltage you have concentration losses).
I hope this will help you
Simple.
9 years ago
22 sept. 2016, 10:18 UTC+2
Thanks Daniel for the reply. But what will be the average current density expression in the probe? Before I give a parametric sweep I need to understand what exactly goes into the X axis and Y axis. X-axis: average current density which is defined as a probe in definitions (Is it phil or phis?) and Y axis is cell voltage (V_cell)
9 years ago
22 sept. 2016, 10:54 UTC+2
1) x_axis ----- average current density measured with a probe on the boundary (pay attention because you can set the siec.llz ,if I rember well, with the electrolyte but generally for an electrochemical system the average current density at the electrolyte interface is different from that measured at the electrode surface as Goodenough teach). Try yourself.
2)y_axis ------ here obviously you will have Vcell (phis). NOT phil.
Rember that phil is the electrolyte potential, different from the physical one. Look at the doc to understand better.
9 years ago
22 sept. 2016, 16:46 UTC+2
Hey Daniel,
Where do you think I should apply the probe for current density? I am doing everything I can but just not able to get the polarization curve...I am looking to get the curve for discharge by giving the cell voltage below the OCV i.e. the equilibrium potential of cathode.
Can you look into the model attached and let me know what is going wrong with it?
Hey Daniel,
9 years ago
22 sept. 2016, 21:41 UTC+2
Sorry I can't open because it was created with a new version.
Open the file where I draw in Paint a conceptual scheme where you should place your probes.
9 years ago
23 sept. 2016, 12:19 UTC+2
Thank you so much Daniel. It worked like a charm. I understood exactly whats happening in simulation now. Next I tried to apply the secondary current distribution physics to the same model and used the Butler volmer equation to describe the over potential of the electrodes. But again I have problem now with simulating it. It shows that the maximum iteration is reached and the solution did not converge.
As per my knowledge, the simulation should calculate the loss of current due to the overpotential and add it to the losses it found out from the primary current distribution. In the simplest way possible, Is my idea right?
Also, do you have any idea how do I go forward with this? how can I implement the secondary current distribution to the model?
9 years ago
23 sept. 2016, 14:25 UTC+2
I'm pleased for the result. The problem could be resolved by increasing the number of iterations performed by comsol. Tipically the value is around 400 by default and you could increase up to 600 in the solver but from direct experience sometimes the problems are related to a bad definitions of BC or irrealistic values.
You should describe better your battery because for every application there are a lot of parameters to set.
It is a PEM?SOFC?MCFC? or other? Porous or non porous electrode???
Remember that the secondary module introduce the butler-volmer relation which is not easy to apply due to the value of transfer coeff., active surface area and so on.
For example try to use the values proposed by Costamagna for one-step reaction.
