Changing dipole parameters via livelink
Sudaraka Mallawaarachchi
I need to simulate an emitter with 100 dipoles, part by part using randomly generated phases and coordinates. I have been able to create the geometry using Livelink (Matlab) but I can't find a wayto change the dipole parameters (Magnitude, direction).
Is there a way to do this?
My code so far creates the points at the random locations (X(i), Y(i)) and allocates an Electric Point Dipole to each point.
for i = 1:NumPS
p1 = geom2.feature.create(['p' num2str(i)],'Point');
p1.set('p',[X(i) Y(i)])
clear p1
geom2.run;
model.physics('ewfd').feature.create(['epd' num2str(i)],'ElectricPointDipole',0);
model.physics('ewfd').feature(['epd' num2str(i)]).selection.set(i)
end
I am also wondering whether there is a comprehensive API available for livelink (Matlab). I tried to find one for days with no luck...
Any help is highly appreciated.
0 Replies Last Post 29 sept. 2016, 17:22 UTC+2
Hello Sudaraka Mallawaarachchi
