mems based high Q resonator
sir
i want to know why high Q is nessary in resonators and which type resonators will gv high Q at high freq(GHz)
generally disk resonator gives high Q around 11500 other then that
and which type couple field analysis we should use.
and how we can increase the quality factor
3 Replies Last Post 18 oct. 2013, 09:52 UTC+2
Posted: 1 decade ago 7 janv. 2011, 08:12 UTC+1
well for me your question is the quest of most "resonator" engineers, there is no one answer anyhow. But I can just remind you that Q is related to damping and damping is in my view one of the most difficult thing to model correctly, because there are many physical phenomena that bring damping, including the "numerics" and sometimes the solvers themselves
Hi well for me your question is the quest of most "resonator" engineers, there is no one answer anyhow. But I can just remind you that Q is related to damping and damping is in my view one of the most difficult thing to model correctly, because there are many physical phenomena that bring damping, including the "numerics" and sometimes the solvers themselves -- Good luck Ivar
Posted: 1 decade ago 7 janv. 2011, 08:22 UTC+1
thank u sir for ur reply
sir as you said Q is related to damping and which is difficult to model,
sir can u reply what r the different physical phenomena that bring damping, including the numerics and sometimes the solvers .
thank u sir for ur reply sir as you said Q is related to damping and which is difficult to model, sir can u reply what r the different physical phenomena that bring damping, including the numerics and sometimes the solvers .
Posted: 1 decade ago 18 oct. 2013, 09:52 UTC+2
hi,Ivar
if i just consider the air damping ,could you just give me an example?
hi,Ivar if i just consider the air damping ,could you just give me an example?
