External geometry function
How to add geometry as a sine function (which is not a defined tag like r1 - rectangle in COMSOL) through Matlab?
5 Replies Last Post 27 oct. 2016, 08:52 UTC−4
Posted: 9 years ago 19 oct. 2016, 14:52 UTC−4
You really don't need to use MATLAB for that: a "parametric curve" can do that for you in the GUI. Now, if you want to know what the MATLAB code for it is, do it in the GUI and save as an m file, as always.
You really don't need to use MATLAB for that: a "parametric curve" can do that for you in the GUI. Now, if you want to know what the MATLAB code for it is, do it in the GUI and save as an m file, as always. Jeff
Posted: 9 years ago 20 oct. 2016, 13:24 UTC−4
Thanks Jeff. Its pretty good :)
Posted: 9 years ago 27 oct. 2016, 05:41 UTC−4
After creating geometry using parametric curve, I built union to make a close geometry from 2 parametric curves and 2 lines. I am not able to select this geometry boundaries in laminar flow physics. I am also attaching the input file. Please help.
Priyanka
Hi, After creating geometry using parametric curve, I built union to make a close geometry from 2 parametric curves and 2 lines. I am not able to select this geometry boundaries in laminar flow physics. I am also attaching the input file. Please help. Thanks Priyanka
Posted: 9 years ago 27 oct. 2016, 08:50 UTC−4
Priyanka,
Use Conversions/Convert to Solid option, as shown in the attached image.
Sergei
Priyanka, Use Conversions/Convert to Solid option, as shown in the attached image. Regards, Sergei
Posted: 9 years ago 27 oct. 2016, 08:52 UTC−4
Thanks Sergei.
Thanks Sergei.
