9 years ago
28 oct. 2016, 08:13 UTC+2
Have you read carefully the pdf document coming along the tutorial?
Exchange current density is the inherent rate of an electrochemical reaction:
i0 = n·F·k0·(cO)^a·(cR)^(1-a), 0 < a < 1 (charge transfer coefficient)
Butler-Volmer gives you the local current density, but the measured current is an integral value over the whole electroactive area. That is the disadvantage of electrochemistry, i.e. current is not selective.
BR
Lasse
BR
Lasse
9 years ago
2 nov. 2016, 04:35 UTC+1
Sir Thank you for your reply.
But Sir I am confused of whether the local current density and exchange current density is on the particle surface of electrode or on the overall electrode?
9 years ago
2 nov. 2016, 08:21 UTC+1
Exchange current is not a directly measurable quantity. As I explained it is the measure of the rate of the electrode reaction. Although current were zero, i.e. the two terms in Butler-Volmer equation cancel each other out, there is exchange current. All electrochemical reactions take place on the surface.
Local current density is local, it can vary along the surface and it can be different at different parts of the electrolyte solution. This is known as the primary current distribution. Only with very specific experimental arrangements you can possibly measure the current distribution on the electrode surface. For example, grain boundaries are electrochemically more active than plateaus. A catalyst particle on the surface has a higher current density that its surroundings. That is why modeling is useful.
[QUOTE]
[/QUOTE]
8 years ago
3 déc. 2016, 10:43 UTC+1
Thank You Sir for your reply
