14 janv. 2011, 12:41 UTC+1
First of all this applies only to dependent variables w.r.t. space variables.
So if you have defined a dependent variable "u" of the space x,y,z COMSOl will generate ux, uxx, uy, uyy, uz, uzz, uxy, uxz, uyz, ut, utt (see he doc) all first or second derivative w.r.t. space variable x,y,z respectively or the time "t"
but (pls check I do not know if it i fully true) you need to use the d(,) operator to get a derivative of something else than a depedent variable, and I believe you can only derive w.r.t x,y,z, r,phi or t (to be confirmed). But it's all written in the doc, use an indexer to help you find things in there
14 janv. 2011, 17:23 UTC+1
Hi, Ivar, Thanks for your answer.
I find the content in doc about the derivative operator. there is a sentence as " The expressions d(u^2,u) and pd(u^2,u) both equal 2*u ", from this we can see that u is not a independent variable as x, y, z or t. Am I right?
[QUOTE]
[/QUOTE]
14 janv. 2011, 22:28 UTC+1
take a look at Magnus (he's from COMSOL ;) reply here
www.comsol.eu/community/forums/general/thread/12911/#p34421
http://www.comsol.eu/community/forums/general/thread/12911/#p34421
