how to get a value of dependent varible with time at boundaries?
GaneshM Battery Modelling
Hi..
I need to get a value of dependent variable w.r.t time at boundaries . How can I write the expression for it?
for example, in 1D phi1 and phi2 are dependent variables and function of both(x,t) in subdomain 1 containing 2 boundaries.
I have to get the values of phi1 at boundary 1 with function of time. Similarly, phi2 at boundary 2 with function of time.
How to define V_cell= phi1( at boundary 1)-phi2(at boundary 2) at each time ?
thanks
regards
Ganesh
4 Replies Last Post 21 janv. 2011, 16:54 UTC+1
Posted: 1 decade ago 16 janv. 2011, 18:28 UTC+1
check the KB on the main site, ther are a few entries on time derivatives therin, I believe you should get your reply from there ;)
And many things of V4 are still applicable for 3.5a
Hi check the KB on the main site, ther are a few entries on time derivatives therin, I believe you should get your reply from there ;) And many things of V4 are still applicable for 3.5a -- Good luck Ivar
Posted: 1 decade ago 21 janv. 2011, 09:36 UTC+1
Hi Ivar,
I have tried to get the values of dependent variables wit time at boundaries using boundary integration variables.
I have defined phi100 = phi1 at boundary 1
and phi201 = phi2 at boundary 2 in boundary integration variables
will they give the values of dependent variables at boundaries each time?
is this the correct way to get the values at each time?
thanks
ganesh
Hi Ivar, I have tried to get the values of dependent variables wit time at boundaries using boundary integration variables. I have defined phi100 = phi1 at boundary 1 and phi201 = phi2 at boundary 2 in boundary integration variables will they give the values of dependent variables at boundaries each time? is this the correct way to get the values at each time? thanks ganesh
Posted: 1 decade ago 21 janv. 2011, 15:12 UTC+1
If you do an integration over a boundary (typically a 2D surface in 3D mode or a line/edge in 2D mode) then you are getting the integrated (summed) value over each element *dx*dy (2D) or times dx (1D). So a heat Flux Q[W/m^2], in 3D gives you. Note: COMSOL is integrating by "advanced" summation with loca higher order polynomial fitting.
Q_tot [W] = integration_overboundary of ( Q[W/m^2] *dx*dy )
If you have done a parametric saweep or a time series (transient analysis), when you plot this you get the Q_tot versus time or Parameter values
Hi If you do an integration over a boundary (typically a 2D surface in 3D mode or a line/edge in 2D mode) then you are getting the integrated (summed) value over each element *dx*dy (2D) or times dx (1D). So a heat Flux Q[W/m^2], in 3D gives you. Note: COMSOL is integrating by "advanced" summation with loca higher order polynomial fitting. Q_tot [W] = integration_overboundary of ( Q[W/m^2] *dx*dy ) If you have done a parametric saweep or a time series (transient analysis), when you plot this you get the Q_tot versus time or Parameter values -- Good luck Ivar
Posted: 1 decade ago 21 janv. 2011, 16:54 UTC+1
Hi.. thanks for the reply..
I used this boundary integration in 1D geometry. I think it will consider the value at that point (1D)on boundary.
so, it represents the value of phi1 at that point at each time. isn't it?
thanks
ganesh
Hi.. thanks for the reply.. I used this boundary integration in 1D geometry. I think it will consider the value at that point (1D)on boundary. so, it represents the value of phi1 at that point at each time. isn't it? thanks ganesh
