Beam Cross Section (bcs) interface returns odd results
Posted 18 nov. 2016, 15:03 UTC−5 Geometry, Structural Mechanics Version 5.2 4 Replies
I was trying out the Beam Cross Section (bcs) interface in 2D to obtain some data I need for my graduation project.
I need to calculate Shear Correction Factor (ky), Max Shear Stress Factor (muy) Torsional constant (J) and Torsional Section Modulus(Wt) for a non-standard cross section.
To try out the interface I imported the geometry of a pipe with outer diameter 25.4mm and 2mm wall thickness, which is easy to calculate from formulas and so I could compare the results and check if I was doing it right. The formulas are found in COMSOLs user guide for the structural mechanics module.
However, the returned data for Torsional Section Modulus and Shear Correction Factor ar far from what is expected for that cross section: Ky should be around 1.9 but returns 0.5 and Wt should be in the 1.5e-6 order but returns 9.5e-8. Other data like area, moment of inertia, section height return correct numbers.
I attach the file I'm using if you can check if there´s any problems with the geometry, since using solid cross sections returns expected values (ex: a solid circular bar or square bar), and hollow cross sections return weird values (ex: hollow rectangular cross section or hollow round section).
Hope all this makes sense. I also attach a file with the beam interface were you can see the values COMSOL itself calculated on another study in table 3. Just in case I'm doing something worng ;) . Hope you can help me out.
4 Replies Last Post 21 nov. 2016, 10:26 UTC−5
