Meshing high aspect ratio objects
Posted 7 déc. 2016, 16:44 UTC−5 Heat Transfer & Phase Change, Geometry, Mesh Version 4.4 1 Reply
Hi All,
I am trying to model a single unit of a counter-flow heat exchanger. The channels are half circles with diameter of 1 cm. If the length is short (<10 cm) comsol does fine. If the length increases then things start looking weird and comsol has errors in building the mesh. Any ideas on what might be going on and how I might address it?
The attached pic shows a 5 cm long channel on the left and a 20 cm long channel on the right.
Thank you,
Bryan
Thank you,
Bryan
1 Reply Last Post 8 déc. 2016, 08:13 UTC−5
