Combustion
Can anyone help?
Calculate the equilibrium composition for the reaction H2O to H2 + ½ O2 for the
ratios on n(H)/n(O) = 1.5. The temperature is 2500K, and the pressure is 3 atm.
I have done it for n(H)/n(O) = 2, which was much easier as H20 cancelled out however cannot do it with a ratio of 1.5.
5 Replies Last Post 22 déc. 2016, 21:18 UTC+1
Posted: 8 years ago 22 déc. 2016, 08:49 UTC+1
Three variables: n(H2), n(O2), n(H2O)
Three constraints:
1. Ideal gas law for the total amount nTOT = n(H2) + n(O2) + n(H2O); p·V = nTOT·R·T
2. n(H)/n(O) = 1.5
3. Reaction equilibrium constant.
The rest is algebra. (Ideal gas law applies very well in your conditions.)
Best wishes
Lasse
Three variables: n(H2), n(O2), n(H2O) Three constraints: 1. Ideal gas law for the total amount nTOT = n(H2) + n(O2) + n(H2O); p·V = nTOT·R·T 2. n(H)/n(O) = 1.5 3. Reaction equilibrium constant. The rest is algebra. (Ideal gas law applies very well in your conditions.) Best wishes Lasse
Posted: 8 years ago 22 déc. 2016, 13:04 UTC+1
How exactly do I use the equation p·V = nTOT·R·T for this since we are not given any volume.
Do I have to find the volume and if so what do I do after finding that.
Very confused with this problem. Been stuck on it for 1 week now.
Many thanks
Net One
How exactly do I use the equation p·V = nTOT·R·T for this since we are not given any volume. Do I have to find the volume and if so what do I do after finding that. Very confused with this problem. Been stuck on it for 1 week now. Many thanks Net One
Posted: 8 years ago 22 déc. 2016, 15:30 UTC+1
The problem you are describing is equilibrium thermochemistry. I don't have the Comsol reaction chemistry module but I have encountered this sort of problem in research on chemical vapor deposition.
This is a classic problem in chemical engineering. Briefly, if you know the standard free energy of all the species involved it's a matter of algebra. If there are only three possible components the algebra will be easy. (And you don't need a finite element application to solve).
However- at 2500 K there are lots of other possible species, sometimes present in very small concentrations. Do you care about atomic oxygen and hydrogen? Ozone? Molecular radicals?
Is this just a starting point for a chemical kinetics problem?
D W Greve
DWGreve Consulting
The problem you are describing is equilibrium thermochemistry. I don't have the Comsol reaction chemistry module but I have encountered this sort of problem in research on chemical vapor deposition. This is a classic problem in chemical engineering. Briefly, if you know the standard free energy of all the species involved it's a matter of algebra. If there are only three possible components the algebra will be easy. (And you don't need a finite element application to solve). However- at 2500 K there are lots of other possible species, sometimes present in very small concentrations. Do you care about atomic oxygen and hydrogen? Ozone? Molecular radicals? Is this just a starting point for a chemical kinetics problem? D W Greve DWGreve Consulting
Posted: 8 years ago 22 déc. 2016, 17:24 UTC+1
I would take, say, 1 m3 volume.
But this is not a Comsol problem at all.
BR
Lasse
I would take, say, 1 m3 volume. But this is not a Comsol problem at all. BR Lasse
Posted: 8 years ago 22 déc. 2016, 21:18 UTC+1
If you want only the answer to this particular problem, use the on-line calculator
www.crct.polymtl.ca/equiweb.php
If you want only the answer to this particular problem, use the on-line calculator http://www.crct.polymtl.ca/equiweb.php
