Filled Tables Re-evaluation
After re-running a study that contains a parametric sweep; reevaluating tables clears the table settings. Converting the table settings to a filled table allows me to plot the table data the way I want in a table graph. Is there a way to keep the table settings while re-evaluating the data from the updated study? More broadly, is there a way to update all results with new study solutions without having to reassign the data set for each plot group?
Thank you,
-Matt
1 Reply Last Post 5 janv. 2017, 15:10 UTC+1
Posted: 9 years ago 5 janv. 2017, 15:10 UTC+1
Hi Matthew,
If I understand correctly, you have a table containing post-processing data that requires several steps to fill in, and you would like to update it in a single click after you've rerun the model with different inputs to the model, correct?
If so, you could build an app using the Application Builder, presuming you're using COMSOL on Windows. The Application Builder includes a capability called "Record Code" that lets you record operations you perform in the GUI and turns them into code (a "method"). This makes it quite easy to "code" something you know how to do in the GUI.
If you have not used the Application Builder before, you'll find some good archived webinars about it elsewhere on the COMSOL website (www.comsol.com/events/webinars/archive?eventtype%5B%5D=event_webinar&startTime=8&endTime=20&view=cards&events_sort=date), including some that show the "Record Code" functionality.
Hi Matthew, If I understand correctly, you have a table containing post-processing data that requires several steps to fill in, and you would like to update it in a single click after you've rerun the model with different inputs to the model, correct? If so, you could build an app using the Application Builder, presuming you're using COMSOL on Windows. The Application Builder includes a capability called "Record Code" that lets you record operations you perform in the GUI and turns them into code (a "method"). This makes it quite easy to "code" something you know how to do in the GUI. If you have not used the Application Builder before, you'll find some good archived webinars about it elsewhere on the COMSOL website (https://www.comsol.com/events/webinars/archive?eventtype%5B%5D=event_webinar&startTime=8&endTime=20&view=cards&events_sort=date), including some that show the "Record Code" functionality. Best, Jeff
