Radial field components set to zero in 2d axisymmetrical in rf module
Posted 24 janv. 2011, 10:54 UTC−5 RF & Microwave Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.1 1 Reply
Hello all,
I'm trying to calculate the scattering electric field in a 2d axisymmetric rf module problem. I define the background field as Er=exp(j*emw.k0*z). That means that the wave is propagating in the positive z axis direction.
The problem is when I try to look at the far field pattern. Apparently, the electric field is set to zero at the r=0 plane. That means that no matter what, at the angle zero in front of my structure in the far field I get zero scattered field.
I know that the radial field is set to zero because of discontinuity of the field.
Is there any way to over come this problem?
Moshe
Moshe
1 Reply Last Post 24 janv. 2011, 11:18 UTC−5
