FSI with solid contact in the fluid domain
Posted 16 janv. 2017, 17:19 UTC−5 MEMS & Nanotechnology, Fluid & Heat, MEMS & Piezoelectric Devices, Microfluidics, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 5.2a 0 Replies
Problem #1) In any contact problem, the gap between the object becomes zero. This creates inverted mesh in the fluid domain between the contacting bodies. What is the solution for this? The solver gets stuck because of inverted mesh warning in the contact zone.
Problem #2) In the solid mechanics node of the FSI, if a prescribed displacement is defined, it will overwrite the fluid-solid boundary condition. This is a very limiting! My solid problem is entirely displacement oriented with displacement defined on boundaries. Does anyone has a recommendation for this?
The model is attached.
Thanks for helping out!
Hello Seyed Mohammad Javid Mahmoudzadeh Akherat
